Clabbe 137 #1 Публикувано 10 Февруари, 2016 Hi Guys, wondering if anyone can recommend a trusted mechanic (have had enough of workshops that just finds "more" problems as soon as they touch the car) in Sofia area? Or if anyone here is handy and wants to earn some money? Need the following work to be done; - Change the rear shock absorbers - Install new lowering springs front and back. - Install new intake manifold, which will require some modification to existing cables/sensors - Try to bend back one of the bars that holds the fuel tank as it has been bent. Any tips or recommendations would be welcome! If the work could be done over a weekend that would even be better. //C. Сподели публикацията Адрес на коментара Сподели в други сайтове
Clabbe 137 #2 Отговорено 11 Февруари, 2016 97 views and no recommendations? Сподели публикацията Адрес на коментара Сподели в други сайтове
Янушев 40 #3 Отговорено 13 Февруари, 2016 Ask fenabg he is from Dupnitsa.75km from Sofia.He is very good mechanic. Сподели публикацията Адрес на коментара Сподели в други сайтове
fenabg 2985 #4 Отговорено 13 Февруари, 2016 56km. 2 Сподели публикацията Адрес на коментара Сподели в други сайтове
barsi 265 #5 Отговорено 13 Февруари, 2016 Fenabg is good choice. Work good and know above the Honda a lot of problems. If you want to repair your car in Sofiq go to " Georgi belov " in " Mladost" . On this street have s service with car wash. Looking for Slavi. He is professional for repair all of cars and sell and tires and motor oil. Сподели публикацията Адрес на коментара Сподели в други сайтове
