Kris_VD
OBD кодове за Accord 5 2.0 TDI (20T2N)
Здравейте колеги хондаджии,
Опитвам се да намеря таблица с кодовете за грешки на OBD за европейски Accord 5-та генерация с Rover 20T2N турбо-дизел.
Потърсих доста из форума, но не успях да намеря тази информация никъде. Попитах и Чичко Гугъл, и резултата беше подобен. Колата е на приятелка и в момента е в сервиз, но "майстора" не знаел какви са кодовете и я накарал тя да си ги търси та се опитвам да и помогна.
Открих следната таблица в някакъв MG-Rover форум, но нямам никаква идея дали е вярна:
You have to connect 4 and 15 pin.
Fault code Location of fault1 The pressure switch has a open circuit or stuck in off position or a fluid leak.12 A open or short circuit in pump motor.13 Is a high pressure leak.14 The pressure switch has a short circuit or is stuck in on position or ECU fault.18             The relief valve or outlet solenoid or pressure switch has accumulator gas leakage.21 Is a open or short circuit or ECU fault with hand brake on or hydraulic fluid low.31 Front right hand wheel speed sensor is intermittent.32 Front left hand wheel speed sensor is intermittent.34 Rear right hand wheel speed sensor is intermittent.38 Rear left hand wheel speed sensor is intermittent.312 Diameter of road wheel.41 Front right hand wheel speed sensor has a open or short circuit.42 Front left hand wheel speed sensor has a open or short circuit.44 Rear right hand wheel speed sensor has a open or short circuit.48 Rear left hand wheel speed sensor has a open or short circuit.5 Locking of right hand or left hand rear wheel.54 Locking of right hand rear wheel.58 Locking of left hand rear wheel.6   Front or rear fail safe relay has a open or short circuit.61 Front fail safe relay has a open or short circuit.64 Rear fail safe relay has a open or short circuit.71 Right hand front solenoid valve.72 Left hand front solenoid valve.74 Rear solenoid valve.81 Is no signal below 6 mph or ECU from wheel speed sensor.82 The ECU84 The ECU
Някой може ли да ми потвърди дали това е вярно? А ако можете да ме опътите към точната таблица още по-добре.
Също така бих помолил да ми препоръчате свестен сервиз в Пловдив, където евентуално биха могли да диагностицират колата компетентно.
Благодаря Ви предварително!
Редактирано от Kris_VD
Здравей колега, инсталирай си Autodata и виж там. Поздрави!
Редактирано от martins
