teror1sta 44 #1 Публикувано 27 Декември, 2010 Понеже дето сме с Д-серия не сме само ние хора Да кача нещо за H и F серията Tranny Code + It's Origin M2A4 - JDM 4G M2B4 - JDM 4G LSD M2F4 - USDM 4G M2U4 - JDM 5G Type-S ATTS/USDM Type-SH ATTS M2Y4 - JDM/USDM 5G Base M2Z4 - JDM 5G SiR S-Spec/JDM 5G w/ LSD option T2T4 - JDM Accord SiR-T (F20B) LSD T2W4 - JDM Accord Euro-R LSD U2Q7 - EDM Accord Type-R LSD M2T4 - BB6 H22A SiR LSD M2L5 92-96 Prelude S (F22A1) M2S4 92-96 Prelude Si (H23A1) M2J5 92-96 Prelude Si (JDM F22B) P2A5 94-97 Accord DX/LX P2U5 94-97 Accord EX P2A4 94-97 Accord Lx/EX Wagon M2J4 - EuDM 2.0i (F20A4) M2K4 - EuDM 2.3i 4ws (H23A2) M2F5 - EuDM 2.2i VTEC (H22A2) M2X5 - EuDM 5g Vti-S (H22A5) M2V5 - EuDM 5g Vti 4WS (H22A5) M2P4 - EuDM 5g Vti-S 4WS M2R4 - Vti-S 1999<-updated? M2C4 - 4th gen BA8 (F22A2) ------------------------------------------------------------ Tranny Code + Gear Ratios M2A4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266 M2B4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266 LSD M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266 M2U4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 ATTS M2Y4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 M2Z4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD T2T4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSD U2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD M2T4 - M2L5 - 3.307 - 1.810 - 1.230 - 0.903 - 0.705 - 4.062 M2S4 - 3.307 - 1.857 - 1.320 - 1.034 - 0.812 - 4.266 M2J5 - 3.307 - 1.810 - 1.269 - 0.966 - 0.787 - 4.062 P2A5 - 3.307 - 1.809 - 1.185 - 0.903 - 0.685 - 4.062 P2U5 - 3.307 - 1.809 - 1.185 - 0.933 - 0.685 - 4.062 P2A4 - 3.307 - 1.809 - 1.185 - 0.903 - 0.685 - 4.062 M2J4 - 3.285 - 1.807 - 1.266 - 0.966 - 0.787 - 4.266 M2K4 - 3.307 - 1.809 - 1.269 - 0.966 - 0.757 - 4.266 M2F5 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.062 M2X5 - M2V5 - 3.285 - 1.950 - 1.344 - 1.071 - 0.870 - 4.062 M2P4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 M2R4 - M2C4 - 3.307 - 1.809 - 1.230 - 0.933 - 0.757 - 4.266 Сподели публикацията Адрес на коментара Сподели в други сайтове
Accord F18A 1 #2 Отговорено 27 Декември, 2010 Супер си колега.Сега ако кажеш и от къде може да се намери някоя кутийка от групата на първия абзац, еле пък тези T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSDU2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD Сподели публикацията Адрес на коментара Сподели в други сайтове
batkosio 15 #3 Отговорено 28 Декември, 2010 Обединеното кралство... Сподели публикацията Адрес на коментара Сподели в други сайтове
Accord F18A 1 #4 Отговорено 29 Декември, 2010 Обединеното кралство...То добре от Обединеното кралство, но как да я намеря?Питах Founder и Boss Hogs но нямат и не ми предложиха да ми поръчат.Намерих на едно място М2А4, но не е ясно в какво състояние е, защото е качвана на няколко коли и до колкото разбрах последно е върната на продавача поради някаква причина. Сподели публикацията Адрес на коментара Сподели в други сайтове
batkosio 15 #5 Отговорено 30 Декември, 2010 M2A4 е японска без LSD. Аз в момента съм с M2B4, малко по-дълги предавки от кутиите в Акорд Тайп Р, и друг принцип на шпера. Според мен това е най-добрата кутия като съотношение вървеж/разход. А кутия можеш да намериш във форумите най-вече, както и в ebay.co.uk. Сподели публикацията Адрес на коментара Сподели в други сайтове
murdera 384 #6 Отговорено 30 Декември, 2010 Прелюд 4 ген h23M2K4 - 3.307 - 1.809 - 1.269 - 0.966 - 0.757 - 4.266Това го пише и на ск. кутия ама тея предваки нямат нищо общо с реалната скорост.За пример 2ра 6500 об. по тези данни трябва да прави 96,а прави ~90.При прекъсвач(7200) трябва да прави 107(ама някой път ) прави ~ 102. Не знам защо се получава тази разлика.И при 3та , 4та и 5та е така. Сподели публикацията Адрес на коментара Сподели в други сайтове
Dragi4 1506 #7 Отговорено 30 Декември, 2010 Аз имам M2A4 кутия в склада Хубава тема Сподели публикацията Адрес на коментара Сподели в други сайтове
jivaka 164 #8 Отговорено 30 Декември, 2010 Прелюд 4 ген h23M2K4 - 3.307 - 1.809 - 1.269 - 0.966 - 0.757 - 4.266Това го пише и на ск. кутия ама тея предваки нямат нищо общо с реалната скорост.За пример 2ра 6500 об. по тези данни трябва да прави 96,а прави ~90.При прекъсвач(7200) трябва да прави 107(ама някой път ) прави ~ 102. Не знам защо се получава тази разлика.И при 3та , 4та и 5та е така. с какъв размер гуми Сподели публикацията Адрес на коментара Сподели в други сайтове
murdera 384 #9 Отговорено 30 Декември, 2010 (Редактирано) 215/40/17 или 195/60/15(сега) А разликата на 3та и 4та е ужасно много... или оборотомера показва повече обороти от реалните или нз пс.иначе м/у 17ките и 15ките има малка разлика в показването,но е незначителна на 3та при 7000об. по километраж е ~140.по предавателните числа и гумите трябва да е 150 Редактирано 30 Декември, 2010 от murdera Сподели публикацията Адрес на коментара Сподели в други сайтове
jivaka 164 #10 Отговорено 30 Декември, 2010 може някакво отклонение да дават скоростомера или обортомерапримерно Сподели публикацията Адрес на коментара Сподели в други сайтове
murdera 384 #11 Отговорено 30 Декември, 2010 (Редактирано) километража е тестван с GPS при 17ките(които са 3мм по ниски от default) разликата е м/у 0.5 и 1км при 100/ч. При 15ките(които са 1.2мм по високи от стандартните) разликата е 3км/ч при движение 100км/ч.(97 реални) Т.е като карам 140 по километраж,реалната скорост е още по ниска и се получава доста голяма разлика.Предавките са по-скоро като на ск.кутия M2S4 на А1 двг. Редактирано 30 Декември, 2010 от murdera Сподели публикацията Адрес на коментара Сподели в други сайтове
jivaka 164 #12 Отговорено 30 Декември, 2010 (Редактирано) километража е тестван с GPS при 17ките(които са 3мм по ниски от default) разликата е м/у 0.5 и 1км при 100/ч. При 15ките(които са 1.2мм по високи от стандартните) разликата е 3км/ч при движение 100км/ч.(97 реални) Т.е като карам 140 по километраж,реалната скорост е още по ниска и се получава доста голяма разлика.Предавките са по-скоро като на ск.кутия M2S4 на А1 двг.не същите са както ги даватпреди 3 седмици разглобих M2K4 и M2F5 и числата са абсолютно верни batkosio мисля че грешиш за най-добрата кутия,моята ще е още по добра ,само че без LSD а може и още по добра да се направи ако има една U2Q7 под ръка Редактирано 30 Декември, 2010 от jivaka Сподели публикацията Адрес на коментара Сподели в други сайтове
murdera 384 #13 Отговорено 30 Декември, 2010 според manual-а cut-off-а на h23a1 е 6800 оборота(а според оборотомера ми е ~7200). Възможно ли да има такава разлика и оборотомера да показва 300-400об. повече от реалните над 6000 да речем. Сподели публикацията Адрес на коментара Сподели в други сайтове
batkosio 15 #14 Отговорено 30 Декември, 2010 Говорех за сток кутии, не за редени Иначе и аз харесвам 2 и 3 на U2Q7. Сподели публикацията Адрес на коментара Сподели в други сайтове
Accord F18A 1 #15 Отговорено 30 Декември, 2010 batkosio мисля че грешиш за най-добрата кутия,моята ще е още по добра ,само че без LSD а може и още по добра да се направи ако има една U2Q7 под ръкаА какво си намислил ще споделиш ли колега jivaka? Сподели публикацията Адрес на коментара Сподели в други сайтове
