B E X 3 M
ПРОДАВАМ Нови бош 1700куб високоомни
ПРОДАВАМ Нови бош 1700куб високоомни.
Цена 650лв 4бр.(цената е под реалната -100лв)
0882 282 142 Христо / гр.София
160lb/hour Bosch Fuel Injector with EV1 Connector
Genuine Bosch 1700 cc/min ( 160 lb/hr ) High Impedance Injectors ( Alcohol Compatible )
These injectors flow 1700 cc/min at 43.5 PSI ( 3 BAR ) and are fully compatible with alternate fuels and alcohol! These new injectors from Bosch represent the next generation of high flow injector technology with fast response times, excellent flow pattern and compact design. The price and performance that these injectors represent to the performance aftermarket is unparalleled.
These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
Features:
Genuine, reliable, new Bosch Injectors
Excellent response characteristics
Robust Design
High Impedance
Specifications:
Coil Resistance: 9.1 Ohms / High Impedance
Dead Time: 0.45ms at 14 volts
Static Flow Rate @ 43.5 PSI ( 300kPa ) w/Gas: 1700 cc/min = 160 lb/hr
Static Flow Rate @ 50 PSI ( 350kPa ) w/Gas: 1875 cc/min = 180 lb/hr
Static Flow Rate @ 58 PSI ( 400kPa ) w/Gas: 2000 cc/min = 195 lb/hr
Connector: Bosch EV1
Injector Length: O-Ring to O-Ring: 62 mm
Injector Overall Length: 74 mm
Injector Body Diameter: 16mm
O-Ring: 14.5mm Viton
Acceptable Fuels: Gas/Petrol, alcohol/methanol, E85, CNG
Equivalent Part Numbers:
Bosch 0280158827 - 0 280 158 827
Редактирано от B E X 3 M
