Perko28
Продавам усилвател Sony, предна линия JBL и кабели
Продавам усилвател Sony xplod xm 2200gtx:
  • [*]2-channel car amplifier [*]200 watts RMS x 2 at 4 ohms (250 watts RMS x 2 at 2 ohms) [*]500 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode) [*]low-pass crossover (50-300 Hz, 12 dB/octave) [*]variable bass boost (0-10 dB at 40 Hz) [*]MOSFET power supply and output stages [*]Tri-way capable (Tri-Way crossover required) [*]
CEA-2006 compliant [*]preamp- and speaker-level inputs [*]preamp outputs [*]gold-plated connectors [*]fuse rating: 40A x 2 [*]4-gauge power and ground leads recommended — wiring and hardware not included with amplifier [*]15-3/4"W x 2-3/16"H x 10-7/8"D [*]150 лв.
2- компонентни говорители JBL GT5.OC
Titanium Composite Balanced-Drive
  • [*]Graphite-Reinforced Polytex Woofer Cone with Butyl Rubber Surround [*]Speaker Impedance: 4 Ohms [*]Frequency Response : 60Hz – 21kHz [*]Drop In : 2-3/8" [*]Bottom Mount :2-1/2"
    70 лв.
    2бр. чинчове, 20 кв. силов кабел с бушон и многожилен за колони 2бр. по около 5 метра.
    30 лв.
    За всичко накуп цената е 200 лв.
    Живея в София, но мога да пратя по куриер за ваша сметка.
    За контакт 0888744888 или Perko28@yahoo.com [*]Линк към снимките...
http://www.tuning.bg/forums/index.php?/topic/95463-%D0%BF%D1%80%D0%BE%D0%B4%D0%B0%D0%B2%D0%B0%D0%BC-%D1%83%D1%81%D0%B8%D0%BB%D0%B2%D0%B0%D1%82%D0%B5%D0%BB-sony-%D0%BF%D1%80%D0%B5%D0%B4%D0%BD%D0%B0-%D0%BB%D0%B8%D0%BD%D0%B8%D1%8F-jbl-%D0%B8-%D0%BA%D0%B0%D0%B1%D0%B5%D0%BB%D0%B8/
