Kwot
Honda turbine
Публикувано (Редактирано)
Здравейте, случайно ми попадна тази информация, и реших че ще е интересно и на други колеги http://en.wikipedia.org/wiki/Honda_C_engine
По-специално ей този параграф: 1989 Honda Legend
Honda replaced the variable length intake manifold with a variable geometry turbocharger to the C20A engine used in the Japanese Domestic Market Legend. The turbo with intercooler-equipped engine was the C20AT engine and are extremely rare. Honda pioneered variable-geometry turbo chargers. The "Wing Turbo", as Honda called them, were controlled by an 8-bit processor ECU and they were constantly adjusting. Basically, at low speeds the wings surrounding the turbine wheel inside the compressor housing on the intake side would be nearly closed to speed and direct exhaust pressure precisely on the turbine wheel. At 2000 rpm, the wings would fluctuate and it would act like a much larger turbo to increase fuel economy as needed. This car was quick and powerful, but the price premium over the slightly longer and wider Legend with the 2.7 L naturally aspirated V6 was too much for most, so the car disappeared. This was one of the only production Hondas ever turbocharged from the factory, along with the K23A1 straight-4 engine used in the Acura RDX and the ER straight-4 engine used in the first generation Honda City.
Също така доколкото знам Хонда първи правят и кормилна рейка, която си променя съотношението между волан/ъгъл на завиване на гумите - в S2000.
Редактирано от Kwot
  • Нагоре 3
