phantasm
Турбо KINUGAWA TD05H-20G 7cm Greddy T518Z
Публикувано изображение Публикувано изображение Публикувано изображение
It is the best choice to upgrade stock WRX TD04L turbo to 400 BHP range. Turbo comes with Performance Thrust Bearing kit that can boost more pressure up to 2.0 Bar The material used for the thrust bearing is a special alloy designed for use in applications requiring high strength and good bearing properties. It has up to 10% porosity making it an ideal bearing surface by absorbing the oil like a sponge.
BEARING SYSTEM: Journal Bearing
COOLING SYSTEM: Oil and Water Cooled
COMPRESSOR
WHEEL DIAMETER: Inducer (mm) 52.3; Exducer (mm) 68; Blades 6/6.
COVER DIAMETER: Inlet (mm) 51.2; Outlet (mm) 40.8.
Boost Pressure @ 1 bar (14.7 psi): CFM 640; lb/min 44.4.
TURBINE
WHEEL DIAMETER: Inducer (mm) 55.8; Exducer (mm) 49.1; Blades 12.
FLANGE: STD SUBARU / IMPREZA
NOZZLE AREA (cm^2):  Mitsubishi SPEC
A/R:  Garrett SPEC 0.49
Actuator: Standard @ 14.7 psi
ENGINE SIZE: 2.0~2.5L
WEIGHT: 16 lb
HORSEPOWER (BHP): 350-400
ЦЕНА: 1290 лв
тел. за връзка: 0894/ 330-987
Турбината се намира във Варна и се изпраща из страната по Еконт.
