Guest maistora_1
Subwoofer Pioneer 12",Amplifier MTX, Car Speakers
Guest maistora_1
Dual 6-1/2” Dual-Cone Car Speakers with Polypropylene Cone (Pair)
Model: XP65 - 4 броя/2 комлекта/
Публикувано изображение
Product Features:
Handles up to 90 watts peak power (30 watts RMS)
Low profile ABS grille
Black satin anodized injection-molded polypropylene cone for low distortion and powerful bass response
Black foam surround
11-ounce magnet
.100/.187 terminal strip
Цена - 70 лева за всичките 4 броя
Pioneer 12" Single-Voice-Coil 4-Ohm Subwoofer with Polypropylene Cone Model: TS-W300R
Product Features:
Watts MAX. Music Power : 600W
Watts Nominal Power Handling : 150W
Frequency Response : 20Hz ~ 4kHz
Sensitivity : 91dB
Ohm Rating : 4
Woofer Cone Material : IMPP Composite
Surround : Dual Layer Urethane
Voice Coil : 4 Layer, Long Voice Coil
Voice Coil Bobbin : Aluminum
Damper (Spider) : Y
Projected Pole Yoke with Vented Pole
Magnet Construction : Strontium
Gasket : Molded
http://www.pioneerelectronics.com/pna/prod...6349985,00.html
Цена : 130 лева
MTX 2-Channel Amplifier (RT202)
Product Features:
RMS Power 14.4 VDC
Input
Hi Level w/ Smart Engage
Low Level Input
Crossover(s)
Defeatable, 18dB/Octave, 85 Hz, selectable for High Pass/Low Pass
2 Ohm Load : 75 w x 2
4 Ohm Load : 37.5 w x 2
Bridged 4 Ohm Load : 150 w
Dynamic Power : 14.4 VDC
2 Ohm Load : 100 w x 2
4 Ohm Load : 50 w x 2
Bridged 4 Ohm Load : 200 w
http://www.mtx.com/caraudio/products/ampli...dThunder202.cfm
http://www.mtx.com/caraudio/products/ampli...er202_2_400.cfm
Цена : 200 лева
За контакти : 088 6391688 – Иво
Л.С., ICQ и т.н.
Guest maistora_1
КОЙ ДАВА 300 ЛЕВА ЗА ВСИЧКО - Subwoofer Pioneer12",Amplifier MTX, Car Speakers????
СПЕШНО!
Guest maistora_1
всичко е чисто нововсе още в кутиитене съм ги пробвал даже
Guest slus4o
Момчета, колко е макс размера за колонки във вратите в смисъл тия 6.5 ще влезнат ли или може и по-големи ако това е макса аз купувам единия комплект, ако пича се навие за 30 кинта
Guest Victor
Най-много 17 сантиметрови могат да се съберат.
Guest D16A8
<{POST_SNAPBACK}>
Да. 6.5 инча са. И аз ще трябва да взимам скоро, ама няма да е точно сега.
Guest Magnum
<{POST_SNAPBACK}>
събират се ако не са много дълбоки и не им е огромен магнита. И във всички случаи трябва да се прави фланец, от дърво или от някоя нехигроскопична материя (че МДЧ-то става на нищо като се намокри)
трябва да се пробват
Guest ma4o
за MTX 2-Channel Amplifier (RT202)-100лв :cool:
Guest maistora_1
<{POST_SNAPBACK}>
хехехех - иди питай някъде колко му е цената и тогава давай такъв коментар
на мен 150 лева ми е минимума!!!!!
за чист нов усилвател 150 лева са нищо!американско производство,а не като тия дето ги продават тука с лепенка на гърба - за близкия изток!!!
Guest ma4o
за MTX 2-Channel Amplifier (RT202)-100лв ;)
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
извиняваи ако съм те засегнал ;)
просто си давам офертата ;) и новата ми е 120лв.
Guest maistora_1
Продадени!Моля модераторите да изтрият обявата!
Guest
