искам да питам първо мига седем пъти после един път продължително и четири къси после два продължителни и едно късо,това грешки 7,14и21 ли са?стева въпрос за ecu pwo от б16а1.
Да това са грешките, ето и какво означават:1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor3 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor5 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor7 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor8 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor9 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor15 Ignition Output Signal missing or defective ignition output signal16 Fuel Injector System defective circuit or unplugged / defective fuel injector17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve20 Electrical Load Detector defective circuit or unplugged / defective sensor21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch23 KS (Knock Sensor) defective circuit or unplugged / defective sensor30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor31 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor41 Primary Oxygen Sensor - Heater circuit malfunction43 Fuel Supply System defective or malfunctioning fuel supply system45 System Too Lean or Too Rich malfunction in the fuel monitoring systems48 LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor58 TDC Sensor 2 (Top Dead Center) defective circuit or unplugged / defective sensor61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response63 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system70 Automatic Transmission malfunction with the automatic transmission controls71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire75 Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire76 Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire80 Exhaust Gas Recirculation insufficient flow detected86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem90 Evaporative Emission Control System leak detected in the fuel tank area91 Fuel Tank Pressure Sensor low input92 Evaporative Emission Control System insufficient purge flow
