nastezatelq
Продавам Cd Player Sony Cdx-gt20mp3
Сонито е в добро състояние няма забележки по панела... Работи перфектно.Цена: 90 лв088 92 82 572 или на Л.СMP3/Atrac3Plus playback · Drive-S · RDS-EON tuner · 4 x 45 W (S-MOSFET) · CD-R/RW playback · CD Text · Id3 Tag (Track-, Artist-, Album-) · EQ3 · Detachable front panel Technical Specifications : Tuner : · Tuner Type: SSIR-EXA · ABC (Automatic Bandwidth Control): YES · BTM (Best Tuning Memory): YES · RDS EON: YES · Tuner Station Presets · FM: 8.0 · MW: 6.0 · LW: 6.0 CD Player · Drive-S: YES · Drive-S HX: NO · Mechanism for: 1 x CD · CD-R Playback capability: YES · CD-RW Playback capability: YES · MP3 Playback capability: YES · ID3 Tag display (Track, Artist, Album name): YES · CD Text display: YES · Title Scroll (CD Text): YES · Repeat Play: YES · Shuffle Play: YES Specification Audio : · Digital Filter: 8 fs · D/A Converter: 1 bit · Frequency Response (Hz): 10 - 20,000 · Tolerance (dB): +/-1 · Signal to Noise Ratio (dB): 120.0 Amplifier : · S-MOSFET Output Stage: YES · Output Power, DIN 45324 at 4 ohm (W): 4 x 25 · Max. Output Power, 1 kHz at 4 ohm (W): 4 x 45 · BBE-MP Digital: NO · DSO (Dynamic Soundstage Organizer): NO · EQ 3 (3 Band Equalizer): YES · Loudness: NO · Pre-amp Output (stereo RCA): NO · Selectable High Pass Filter: NO · Sub-Switch (rear out / sub out switchable): NO · Selectable Low Pass Filter in Sub-mode: NO · Sub Volume Control in Sub-mode: NO · AUX Input: NO Others :· 3D Fluorescent Display: NO · Display Type: 13 Segment · Display Colour: 1 colour · Contrast Adjustment: NO · Display Dimmer: NO · Key Illumination: red · Sensor for IR Commander: YES · Removable Front Panel: YES · Security Code: NO · Integrated Clock: 24 h · Telephone Attenuator: YES · ISO Connector: YES · Installation Angle (degrees): 0 - 45 Dimensions : · Width (mm) - approx.: 178.0 · Height (mm) - approx.: 50.0 · Depth (mm) - approx.: 176.0
модераторите да трият или заключват темата
