street_fighter
Продавам бас каса,стъпало и 2x10см Pioneer
Sony XS-L1290P5 12" 1600 Watts Subwoofer
малко инфо тук: http://www.shopcartusa.com/P_Sony_XS-L1290...ofer_XSL1290P5/
-P5 Rigid Aluminum Deposition Cone Design
-4-Layer Voice Coil with Stabilizing Inner Cap
-Durable Foamed Rubber Surround with Stroke Stabilizers
-Double Damper Suspension
-Dual Stacked Magnets
-Gold-Plated Binding Posts
-Rear Voice Coil Vent with Vented Heat Sink
-Rubber Magnet Guard
-Optimized for both Small Sealed and Ported Enclosures
-Rec. Sealed Box Dims: 1.00 cu.ft.
-Rec. Ported Box Dims: 1.50 cu.ft.
-Free Air Usage: not recommended
-Sensitivity: 89 dB
-Frequency Response: 18-2,500 Hz
-Recommended RMS Power: 500W
-Peak Power Handling: 1600W
-Impedance: 4 ohms
-Full Sonic Electronix Warranty
цена:170лв.
Публикувано изображениеПубликувано изображение
Усилвател Thunder TCA 2120
2 х 180 вата RMS на 4 ома
1 х 400 вата RMS на 4 ома (bridge)
Входове - RCA и Hi input
Low pass filter - 50 - 250 Hz
High pass filter - 120 Hz - 3 kHz
Bass boost - 0/6/12 dB at 45 Hz
Предпазител - 2 х 30 ампера
Габаритни размери 360/275/56 мм
цена:90лв
Говорители PIONEER TS-G1001I: http://auto.market.dir.bg/xoffer.php?xoffe...&shop_id=18
чисто нови,неотваряни!
цена:25лв
0899 746 946 -Красимир
ПРОМОЦИЯ ЗА КОМПЛЕКТ - КАСА + БАС + СТЪПАЛО + СРЕДИ + КАБЕЛИ = 270 лв!!
