player
Някои може ли да ми разясни малко за този двигател 1.6 Esi?!
Какво точно означава Esi и такива подробности :whistle:
The uplevel "Si" (called the "ESi" in Europe) model came standard with a 1.6 liter SOHC 16-valve four cylinder engine with Honda's VTEC. The Si also came with 14" alloy wheels which were offered in an optional body color-matched paint scheme on Samba Green models, power side mirrors, cruise control, rear disc brakes and a front anti-sway bar for improved handling.D16Z6 * Found in: o 1992-1995 Honda Civic EX/Si, Del Sol Si, o 1992-1995 Honda Civic ESi (European Market) + Displacement : 1590 cm3 + Bore and Stroke : 75 mm X 90 mm + Compression : 9.4:1 + Power : 125 hp @ 6500 rpm & 106 ft·lbf @ 5200 rpm, 80bhp + VTEC Switchover 4800 rpm + Valvetrain : SOHC VTEC + Fuel Control : OBD-1 MPFI + Head Code : P08 + Head Code (EU): P28
