Izanagi
Обща поръчка на оригинални части Honda и Acura от USA и UK до 23.03.2017г.
Здравейте,
частите трябва да са тук на 14-ти.
Новата тема е тук.
Колеги,
частите са при мен и съм ги сметнал.
Пишете кой кога и как иска да си ги получи.
Р atos85
2х 08L96-TA0-101A Cargo Hook 2х 8,19 = $16,38/ 43.67лв.
1х 91501-S04-003 Clip, Fender (Inner) $1,21/ 3,30лв.
1х 74175-SJA-000 Cushion, Hood $4,20/ 6,99лв.
2х 34262-TL0-305 Lens (Coo) 2х 4,27 = $8,54/ 22,10лв.
2х 79671-STK-A01 Bulb, Neo-Wedge (14V 0.05A) 2х $4,31 = $8,62/ 24.19лв.
2х 38221-SNA-A31 Fuse, Blade (7.5A ) 2х $1,46 = $2,92/ 7.09лв.
2х 38221-SNA-A41 Fuse, Blade (10A ) 2х $1,46 = $2,92/ 7.02лв.
Total: $44.79/ 114.36лв. / Платил 104лв./ Доплащане 10.36лв.
При поръчка от www.coxmotorparts.co.uk
1х 76620-TL0-G01 BLADE, WINDSHIELD WIPER (DRIVER SIDE)(600MM) £10,06
1х 76630-TL0-G01 BLADE, WINDSHIELD WIPER (PASSENGER SIDE)(550MM) £10,06
Total: £20.12
Р zpa0 - от мен
2x 83605-SDA-A02, Holder, Floor Mat 2x $1.94 = $3.88/ 10.45лв.
4x 45172-S04-003, Spring, Shoe Clamp 4x $0.81 = $3.24/ 9.16лв.
4x 45175-SA0-013, Pin, Tensioner 4x $1.93 = $7.72/ 12,94лв.
2x 43172-S04-003, Spring B, Brake Shoe Return 2x $1.29 = $2.58/ 6.57лв.
1x 91501-SEA-003, Clip, FR. Cowl $1.84/ 3,28лв.
Total: $19.26/ 42.40лв./  Платил 40лв./ Доплащане 2,40лв.
Р 5yo - от мен
1x 71598-SL4-013 Spacer, Bumper Side $2.35/ 6.09лв.
3x 91503-SP0-003 Clip A, Bumper 3x $2.82 = $8.46/ 9.38лв.
2x 90657-SB0-003 Clip, Splash Shield 2x $2.76 = $5.52/ 6.23лв.
1x 71144-SR3-A00 Grommet, Bumper Side $0.99/ 1.97лв.
Р 3x 90540-SA7-000 Washer, Bumper 3x $1.76 = $5.28/ 12.79лв.
Р 2x 91516-SK7-013 Clip, Cover (Lower) 2x $3.37 = $6.74/ 16.44лв.
Р 5x 91501-S04-003 Clip, Fender (Inner) 5x $1.18 = $5.90/ 14.42лв.
Total: $35.15/ 67.32лв. / Платил 89лв./ Надплатил 21.68лв.
Р R0SS
2x 91345-RDA-A01 O-Ring (13.0X1.9) 2 x $ 0.55= $1.10/ 2.69лв.
1x 91048-P2A-003 Bearing, Radial Ball (17X40X12) 1 x $10.51=$10.51/ 22.89лв.
1x 91249-PNC-003 -seal, Power Steering Pump 1 x $4.01=$4.01/ 7.53лв.
1x 90693-PAA-A01 Circlip, Inner (40mm) 1 x $1.19=$1.19/ 3.19лв.
1x 91347-PAA-A01 O-Ring (16.7X1.18) 1 x $0.61=$0.61/ 1.53лв.
1x 91347-PLA-003 O-Ring (12.7X1.8) 1 x $1.06=$1.06/ 2.22лв.
1x 91345-R40-P01 O-Ring (13.0X1.9) 1 x $0.66=$0.66/ 1.62лв.
1x 91346-PLA-003 O-Ring (23.8X2.4) 1 x $1.59=$1.59/ 3.31лв.
1x 91348-P2A-003 O-Ring (51.0X2.4) 1 x $0.85=$0.85/ 2.11лв.
1x 91349-PNC-J01 Seal, Pump Cover 1 x $3.64=$3.64/ 7лв.
1x 91349-PNC-003 Seal B, Pump Cover 1 x $3.64=$3.64/ 6.96лв.
2x 53546-S84-003 Boot, Tie Rod End (Nok) 2 x $2.15=$4.30/ 11.29лв.
2x 52454-S84-A01 Boot, Ddust 9Upper) 2 x $6.52=$13.04/ 32.43лв.
4x 91501-S04-003 Clip, Fender (Inner) 4 x $1.18=$4.72/ 13.2лв.
2x 91370-SV4-000 O-Ring (14.4X1.9) 2x $0.78= $1.56/ 3.84лв.
4x 51464-S04-013 Boot, Ball Joint (Upper) 4x $2.28= $9.12/ 24.18лв.
Total: $61,60/ 145.99лв./  Платил 125лв./ Доплащане 20.99лв.
Р dragob
4x 98079-561-4G SPARK PLUG ZFR6F-11 NJK 4x 2,73= $10,92/ 33.30лв.
Платил 27лв. Доплащане 6.30лв.
Р h5rov
1х 12341-RTA-000 Gasket, Cylinder Head Cover $8.46/ 22.47лв.
1x 75700-S9A-G00 Emblem, FR. (H) $6.40/ 16.32лв.
Total: $14,27/ 38.79лв. Платил 16лв. Доплащане 22.79лв.
Р Labbii
2х 75700-S9A-G00 Emblem, FR. (H) 2x $5.81 = $11.62/ 32.64лв.
Платил 28,37лв./ Доплащане 4.27лв.
Р JHM
Платил 16лв. Доплащане 6.47лв.
Р Azz
1x 18715-PB2-000 Gasket, EGR Valve (Ishino Gasket) $5.38/ 13.29лв.
1x 17121-PT3-A01 Gasket, In. Manifold (B) (Ishino Gasket) $5.89 - не е изпратена
2x 35851-SS0-003 Bulb, Neo-Wedge 2x $4.07 = $8.14/ 16.82лв.
1x 46975-SD4-003 Seal, Reserve Tank $3.97/ 9.54лв.
2x 91641-SM4-003 Grommet, Screw (4mm) 2x $1.84 = $3.68/ 8.85лв.
1x 90670-SE0-003 Grommet, Hood Stay $2.93/ 4.09лв.
Total: $29.99/ 52.59лв. / Платил 60лв. / Надплатил 7.41лв.
Niki_V
1x 01464-SNA-A01 Hose Set, R. FR. Brake $34.09/ 85лв.
1x 01465-SNA-A01 Hose Set, L. FR. Brake $33.84/ 86.04лв.
2x 01466-SNA-010 Hose Set, RR. Brake (Drum) 2x$27.39=$54.78/ 142.81лв.
1x 51320-SNA-A02 Link, R. FR. Stabilizer $17.14/ 47.60лв.
1x 51321-SNA-A02 Link, L. FR. Stabilizer $17.14/ 47.60лв.
1x 52320-SNA-A01 Link, R. RR. Stabilizer $14.84/ 42.09лв.
1x 52321-SNA-A01 Link, L. RR. Stabilizer $14.84/ 42.09лв.
Total: $186.67/ 493.23лв. / Платил 470лв. / Доплащане 23.23лв.
Р xeqtr - от мен
2x 90301-ST0-003 Nut, Push (3mm) 2x 1.38 = $2.76/ 4,33лв.
7x 91503-SZ3-003 Clip A, Bumper 7x 2.71 = $18.97/ 20,88лв.
7x 91501-S04-003 Clip, Fender (Inner) 7x 1.18 = $8.26/ 23.10лв.
2x 76632-SVA-A01 Rubber, Blade (625mm) 2x 4.66 = $9.32/ 24.87лв.
2x 76622-SVA-A01 Rubber, Blade (700mm) 2x 4.66 = $9.32/ 25.13лв.
Total: $55.03/ 114.63лв./ Платил 120лв./ Надплатил 5,37лв.
Р _pileto_ - от мен
3x 90682-SEA-003 Clip, Tapping Screw (5mm) 3x$1.60= $4.80/ 7.86лв.
1x 15845-RAA-A01 Filter Assy., VTC $4.60/ 9.56лв.
5x 79671-SMA-941 Bulb, Neo-Wedge (14V 80Ma) 5x$4.67= $23.35/ 26.31лв.
2x 34906-ST5-003 Bulb (12V 21W/5W) (Stanley) 2x$3.38= $6.76/ 11.42лв.
Р 1x 12341-R40-A00 Gasket, Head Cover $8.46/ 22.45лв.
Р 2x 76601-TA0-A01 Arm Piece Cover - 2x$2.19= $4.38/ 10.93лв.
Р 2x 51306-TA0-A01 Bush, FR. Stabilizer Holder - 2x$2.80=$ 5.60/ 18.50лв.
Р 1x 51320-TA0-A01 Link, R. FR. Stabilizer $17.14/ 47.85лв.
Р 1x 51325-TA0-A01 Link, L. FR. Stabilizer $17.14/ 47.85лв.
Р 1x 74150-TA0-A00 Fender Assy., L. FR. (Inner) $41.89/ 135.27лв.
Р 2x 34911-634-611 Bulb (12V 21/5W) (Ece) (Stanley) 2x$2.21= $4.42/ 11.42лв.
Total: $138.54/ 349.88лв./ Платил 400лв./ Надплатил 50.12лв.
Р birev - от мен
2x 91560-S0X-A01 Clip, Door Lining (Natural) 2x $1.43 = $2.86/ 6.86лв.
5x 91560-S84-A01 Clip, Door Lining (Natural 5x $1.45 = $7.25/ 14.91лв.
4x 72143-S04-003 Gasket 4x $2.20 = $8.80/ 21.58лв.
2x 90303-S9A-003 Nut, Garnish (6mm) 2x $2.74 = $5.48/ 11лв.
2x 91545-SE0-003 Clip Assy. (8mm) 2x $3.35 = $6.70/ 7.90лв.
1x 91525-S6A-003 Clip D, FR. Windshield Side Garnish 1x $1.97 = $1.97/ 4.83лв.
2x 91522-S6A-003 Clip B, FR. Windshield Side Garnish (Light Blue) 2x $1.84 = $3.68/ 9.18лв.
3x 91519-S6A-003 Clip A (Black) 3x $1.84 = $5.52/ 13.68лв.
1x 91520-S6A-003 Clip B (Orange) 1x $1.84 = $1.84/ 4.43лв.
1x 91521-S6A-003 Clip A, FR. Windshield Side Garnish (Gray) 1x $1.84 = $1.84/ 4.53лв.
1x 90164-S5A-010 Bolt, Flange (12X40) 1x $2.29 = $2.29/ 6.72лв.
1x 22841-P20-000 Boot, Release Fork 1x $12.78 = $12.78/ 19.13лв.
Total: $61.01/ 124.75лв/  Платил 150лв./ Надплатил 25.25лв.
Р JoroHondata - от мен
1x 53534-ST0-013 Dust Seal, Tie Rod $15.92/ 29.86лв.
1x 53010-S04-000, End set, Rack $58.86/ 123.94лв.
Total: $74,78/153.80лв./ Платил 200лв. / Надплатил 46.20лв.
Р canko79
1x 14516-P0A-000 SPRING COMP., TIMING BELT ADJUSTER $3,95/ 6,05лв.
1x 13407-P0A-000 SPRING, BELT ADJUSTER $2,38/ 4,38лв.
1x 17139-PK1-000 GROMMET, PCV VALVE $2,28/ 3,24лв.
1x 91604-SD2-013 GROMMET, HOOD STAY $0,34/ 0.85лв.
2x 95005-351-851G TUBE, 3.5X185 (95005-35001-10M) $3,98 - не е изпратена
Total: $12,93/ 14.52лв. / Платил 30лв. / Надплатил 15.48лв.
Р Visible
1x 76730-S2X-003 BLADE, WINDSHIELD WIPER (350MM) $14.64/ 38.33лв.
1x 76622-SMA-004 RUBBER, BLADE (650MM) $4.66/ 12.78лв.
1x 76632-SMA-004 RUBBER, BLADE (350MM) $4.27/ 11.14лв.
1x 76622-STK-A02 RUBBER, BLADE(650MM) $4.66/ 14,06лв.
1x 76623-SNA-A12 RUBBER, BLADE(575MM) $4.27/ 11.98лв.
Total: $32.5/ 88.29лв./ Платил 80лв./ Доплащане 8.29лв.
Р Niakoi
2x 52315-SR3-900 Bush, RR. Stabilizer 2x $4.22 = 8.44/ 10,87лв.
4x 52316-SA5-000 Bush, Stabilizer End 4x $1.63 = 7.52/ 13,90лв.
Total: $15,96/ 24.77лв. Платил 40лв./ Надплатил 15.23лв.
Р mirkon4o - от мен
2x 51391-S7A-005 Bush, FR. Compliance 2x13.02= $26.04/ 73,50лв.
2x 51306-S7B-014 Bush, Stabilizer Holder 2x3.32= $6.64/ 15,04лв.
2x 51392-S5A-004 Bush, FR. Arm (Lower) (Yamashita) 2x10.95= $21.90/ 68,02лв.
2x 51225-S5A-003 Boot, Ball Dust (Lower) 2x3.05= $6.10/ 15.57лв.
1x 16456-P8A-A01 Gasket, Rotary Air Control Valve $2.36/ 5,78лв.
Total: $63.04/ 177.91лв./  платил 220лв./ Надплатил 42.09лв.
Редактирано от Izanagi
Привет
Аз ще си взема частите лично- може би след 24 този месец когато ти е удобно да се видим.
Корекция: частите са вече взети ! Благодаря !
Поздрави
Редактирано от JoroHondata
Аз ще си ги взема лично тази седмица.
Sent from my iPhone using Tapatalk
Здравейте,
Днес си взех частите. Благодаря на Пепи за коректното отношение.
Изпратено от моят SM-A520F с помощта на Tapatalk
Всички части са раздадени.
Новата тема е тук.
Поздрави
