Guest didone
кодове
Guest didone
:) тук пък има и обяснения с картинки и то за доста модели :)My Webpage Редактирано от didone
Guest stan4o
Ето ги кодовете до 92;) ко няма да игнорираме 96+ година ХондитеУпссс... сега видях че сложена във по-такива теми... дано сега като е горе да не почнат да пишат. Редактирано от stan4o
Понеже единият линк се е прецакъл пускам този пост МОЛЯ НЕ ПИШЕТЕ В ТЕМАТА :) 1 O2A - Oxygen sensor #12 O2B - Oxygen sensor #23 MAP - manifold absolute pressure sensor4 CKP - crank position sensor5 MAP - manifold absolute pressure sensor6 ECT - water temperature sensor7 TPS - throttle position sensor8 TDC - top dead centre sensor9 CYP - cylinder sensor10 IAT - intake air temperature sensor12 EGR - exhaust gas recirculation lift valve13 BARO - atmospheric pressure sensor14 IAC (EACV) - idle air control valve15 Ignition output signal16 Fuel injectors17 VSS - speed sensor19 Automatic transmission lockup control valve20 Electrical load detector21 VTEC spool solenoid valve22 VTEC pressure valve23 Knock sensor30 Automatic transmission A signal31 Automatic transmission B signal36 traction control found on JDM ecu's41 Primary oxygen sensor heater43 Fuel supply system45 Fuel system too rich or lean48 LAF - lean air fuel sensor54 CKF - crank fluctuation sensor58 TDC sensor #261 Primary oxygen sensor63 Secondary oxygen sensor65 Secondary oxygen sensor heater71 random misfire cylinder 172 random misfire cylinder 273 random misfire cylinder 374 random misfire cylinder 480 Exhaust Gas Recirculation insufficient flow detected86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem90 Evaporative Emission Control System leak detected in the fuel tank area91 Fuel Tank Pressure Sensor low input92 Evaporative Emission Control System insufficient purge flow1. P0010 Variable Valve Timing Control (VTC) Oil Control Solenoid Valve MalfunctionP0011 Variable Valve Timing Control (VTC) System MalfunctionP0101 Mass Airflow (MAF) Sensor Range/Performance ProblemP0102 Mass Airflow (MAF) Sensor Circuit Low VoltageP0103 Mass Airflow (MAF) Sensor Circuit High VoltageP0106 Manifold Absolute Pressure (MAP) Sensor Range/Performance ProblemP0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low VoltageP0108 Manifold Absolute Pressure (MAP) Sensor Circuit High VoltageP0111 Intake Air Temperature (IAT) Sensor Circuit Range/Performance ProblemP0112 Intake Air Temperature (IAT) Sensor Circuit Low VoltageP0113 Intake Air Temperature (IAT) Sensor Circuit High VoltageP0116 Engine Coolant Temperature (ECT) Sensor Circuit Range/Performance ProblemP0117 Engine Coolant Temperature (ECT) Sensor Circuit Low InputP0118 Engine Coolant Temperature (ECT) Sensor Circuit High InputP0122 Throttle Position (TP) Sensor Circuit Low InputP0123 Throttle Position (TP) Sensor Circuit High InputP0125 Engine Coolant Temperature (ECT) Sensor Slow ResponseP0128 Cooling System MalfunctionP0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low VoltageP0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High VoltageP0133 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) Circuit Slow ResponseP0134 Air/Fuel Ratio (A/F) Sensor (Sensor 1) No Activity DetectedP0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit MalfunctionP0137 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit Low VoltageP0138 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit High VoltageP0139 Secondary Heated Oxygen Sensor (Secondary HO2S) Slow ResponseP0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit MalfunctionP0143 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit Low VoltageP0144 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit High VoltageP0145 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit Slow ResponseP0147 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Heater Circuit MalfunctionP0153 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Circuit Slow ResponseP0154 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Heater System MalfunctionP0155 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Heater Circuit MalfunctionP0157 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)Circuit Low VoltageP0158 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)Circuit High VoltageP0159 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)Circuit Slow ResponseP0161 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)Heater Circuit MalfunctionP0171 Fuel System Too LeanP0172 Fuel System Too RichP0174 Front Bank (Bank 2) Fuel System Too LeanP0175 Front Bank (Bank 2) Fuel System Too RichP0191 Fuel Pressure Sensor Range/Performance ProblemP0192 Fuel Pressure Sensor Circuit Low VoltageP0193 Fuel Pressure Sensor Circuit High VoltageP0196 EOT Sensor/Range Performance ProblemP0197 EOT Sensor Circuit Low VoltageP0198 EOT Sensor Circuit High VoltageP0222 Throttle Position (TP) Sensor 2 Circuit Low VoltageP0223 Throttle Position (TP) Sensor 2 Circuit High VoltageP0300 Random MisfireP0301 No. 1 Cylinder MisfireP0302 No. 2 Cylinder MisfireP0303 No. 3 Cylinder MisfireP0304 No. 4 Cylinder MisfireP0305 No. 5 Cylinder MisfireP0306 No. 6 Cylinder MisfireP0325 Knock Sensor Circuit MalfunctionP0335 Crankshaft Position (CKP) Sensor Circuit No SignalP0336P0339Crankshaft Position (CKP) Sensor Circuit Intermittent InterruptionP0340 Camshaft Position (CMP) Sensor No SignalP0341 Camshaft Position (CMP) Sensor A Intermittent InterruptionP0341 Variable Valve Timing Control (VTC) Phase GapP0344 Camshaft Position (CMP) Sensor Intermittent InterruptionP0365 Camshaft Position (CMP) Sensor B No SignalP0366P0369Camshaft Position (CMP) Sensor B Intermittent InterruptionP0385 Crankshaft Position (CKP) Sensor B No SignalP0389 Crankshaft Position (CKP) Sensor B Intermittent InterruptionP0401 Exhaust Gas Recirculation (EGR) Insufficient FlowP0404 Exhaust Gas Recirculation (EGR) Control Circuit Range/Performance ProblemP0406 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High VoltageP0410 Air Pump Circuit MalfunctionP0411 Secondary Air Injection System Incorrect FlowP0420 Catalyst System Efficiency Below ThresholdP0430 Front Bank Catalyst System Efficiency Below Threshold (Bank 2)P0441 Evaporative Emission (EVAP) Control System Incorrect Purge FlowP0442 Evaporative Emission (EVAP) System Small Leak DetectedP0443 Evaporative Emission (EVAP) Canister Purge Valve Circuit MalfunctionP0451 Fuel Tank Pressure (FTP) Sensor Range/Performance ProblemP0452 Fuel Tank Pressure (FTP) Sensor Circuit Low VoltageP0453 Fuel Tank Pressure (FTP) Sensor Circuit High VoltageP0456 Evaporative Emission (EVAP) System Very Small Leak DetectedP0457 Evaporative Emission (EVAP) System Leak Detected Fuel Fill Cap Loose/OffP0461 Fuel Gauge Sending Unit Range/Performance ProblemP0462 Fuel Gauge Sending Unit Circuit Low VoltageP0463 Fuel Gauge Sending Unit Circuit High VoltageP0496 Evaporative Emission (EVAP) System High Purge FlowP0497 Evaporative Emission (EVAP) System Low Purge FlowP0498 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low VoltageP0499 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit High VoltageP0500 Vehicle Speed Sensor (VSS) Circuit MalfunctionP0501 Vehicle Speed Sensor (VSS) Range/Peformance ProblemP0505 Idle Control System MalfunctionP0506 Idle Control System RPM Lower Than ExpectedP0507 Idle Control System RPM Higher Than ExpectedP0511 Idle Air Control (IAC) Valve Circuit MalfunctionP0521 EOP Sensor Range/Performance ProblemP0522 EOP Sensor Circuit Low VoltageP0523 EOP Sensor Circuit High VoltageP0560 ECM Back-up Circuit Low VoltageP0563 Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Source CircuitUnexpected VoltageP0600 Multiplex Control System TroubleshootingP0603 ECM/PCM Internal Control Module Keep Alive Memory (KAM) ErrorP0606 ECM/PCM Processor MalfunctionP0661 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit Low VoltageP0662 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit High VoltageP0685 ECM/PCM Power Relay Control Circuit MalfunctionP0700 Automatic Transmission Control SystemP0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)P0706 Open in Transmission Range Switch CircuitP0710P0711Problem in ATF Temperature Sensor CircuitP0712 Short in ATF Temperature Sensor CircuitP0713 Open in ATF Temperature Sensor CircuitP0715P0716Problem in Mainshaft Speed Sensor CircuitP0717 Problem in Mainshaft Speed Sensor Circuit (No Signal Input)P0718 Mainshaft Speed Sensor Intermittent FailureP0720 Countershaft Speed Sensor Circuit MalfunctionP0720P0721Problem in Countershaft Speed Sensor CircuitP0722 Problem in Countershaft Speed Sensor Circuit (No Signal Input)P0723 Countershaft Speed Sensor Intermittent FailureP0725 Engine Speed Input Circuit MalfunctionP0730 Problem in Shift Control SystemP0731 Problem in 1st Clutch and 1st Clutch Hydraulic CircuitP0732 Problem in 2nd Clutch and 2nd Clutch Hydraulic CircuitP0733 Problem in 3rd Clutch and 3rd Clutch Hydraulic CircuitP0734 Problem in 4th Clutch and 4th Clutch Hydraulic ClutchP0735 Problem in 5th Clutch and 5th Clutch Hydraulic CircuitP0740 Problem in Lock-up Control SystemP0741 Torque Converter Clutch Hydraulic Clutch Stuck OFFP0743 Problem in Torque Converter Clutch Solenoid Valve CircuitP0745 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve A CircuitP0746 A/T Clutch Pressure Control Solenoid Valve A Stuck OFFP0747 A/T Clutch Pressure Control Solenoid Valve A Stuck ONP0748 Problem in A/T Clutch Pressure Control Solenoid Valve A CircuitP0750 Problem in Hydraulic Control System of Shift Solenoid Valve A CircuitP0751 Shift Solenoid Valve A Stuck OFFP0752 Shift Solenoid Valve A Stuck ONP0753 Problem in Shift Solenoid Valve A CircuitP0756 Shift Solenoid Valve B Stuck OFFP0757 Shift Solenoid Valve B Stuck ONP0758 Problem in Shift Solenoid Valve B CircuitP0761 Shift Solenoid Valve C Stuck OFFP0762 Shift Solenoid Valve C Stuck ONP0763 Problem in Shift Solenoid Valve C CircuitP0771 Shift Solenoid Valve E Stuck OFFP0773 Problem in Shift Solenoid Valve E CircuitP0775 Problem in the Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve BCircuitP0776 A/T Clutch Pressure Control Solenoid Valve B Stuck OFFP0777 A/T Clutch Pressure Control Solenoid Valve B Stuck ONP0778 Problem in A/T Clutch Pressure Control Solenoid Valve B CircuitP0780 Problem in Shift Control SystemP0795 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve C CircuitP0796 A/T Clutch Pressure Control Solenoid Valve C Stuck OFFP0797 A/T Clutch Pressure Control Solenoid Valve C Stuck ONP0798 Problem in A/T Clutch Pressure Control Solenoid Valve C CiruitP0812 Open in Transmission Range Switch ATP RVS Switch CircuitP0842 Short in 2nd Clutch Transmission Fluid Pressure Switch Clutch, or 2nd Clutch TransmissionFluid Pressure Switch (Clutch) Stuck ONP0843 Open in 2nd Clutch Transmission Fluid Pressure Switch Circuit, or 2nd Clutch TransmissionFluid Pressure Switch Stuck OFFP0845 Problem in 3rd Clutch Pressure Switch CircuitP0847 Short in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch TransmissionFluid Pressure Switch Stuck ONP0848 Open in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch TransmissionFluid Pressure Switch Stuck OFFP0872 Short in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch TransmissionFluid Pressure Switch Stuck ONP0873 Open in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch TransmissionFluid Pressure Switch Stuck OFFP0962 Problem in A/T Clutch Pressure Control Solenoid Valve A CircuitP0963 Problem in A/T Clutch Pressure Control Solenoid Valve AP0966 Problem in A/T Clutch Pressure Control Solenoid Valve B CircuitP0967 Problem in A/T Clutch Pressure Control Solenoid Valve BP0970 Problem in A/T Clutch Pressure Control Solenoid Valve C CircuitP0971 Problem in A/T Clutch Pressure Control Solenoid Valve CP0973 Short in Shift Solenoid Valve A CircuitP0974 Open in Shift Solenoid Valve A CircuitP0976 Short in Shift Solenoid Valve B CircuitP0977 Open in Shift Solenoid Valve B CircuitP0979 Short in Shift Solenoid Valve C CircuitP0980 Open in Shift Solenoid Valve C CircuitP0982 Short in Shift Solenoid Valve D CircuitP0983 Open in Shift Solenoid Valve D CircuitP0985 Short in Shift Solenoid Valve E CircuitP0986 Open in Shift Solenoid Valve E CircuitP1020 Valve Pause System Stuck OffP1021 Valve Pause System Stuck OnP1025 Valve Pause System Sticking OffP1026 Valve Pause System Sticking OnP1077 Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)P1078 Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance ProblemP1107 Barometric Pressure (BARO) Sensor Circuit Low VoltageP1108 Barometric Pressure (BARO) Sensor Circuit High VoltageP1121 Throttle Position (TP) Sensor Lower Than ExpectedP1122 Throttle Position (TP) Sensor Higher Than ExpectedP1128 Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than ExpectedP1129 Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than ExpectedP1130 Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)(Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance ProblemP1149 Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean RangeP1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High VoltageP1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High VoltageP1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance ProblemP1158 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low VoltageP1159 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low VoltageP1162 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow ResponseP1163 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow ResponseP1163 Air/Fuel Ratio Sensor (Sensor 1) Slow ResponseP1164 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance ProblemP1164 Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/PerformanceP1165 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance ProblemP1165 Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/PerformanceP1166 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical ProblemP1166 Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit MalfunctionP1167 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System MalfunctionP1167 Heated Oxygen Sensor Sensor1 (Primary LAF HO2S) Heater System MalfunctionP1168 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low VoltageP1169 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL High VoltageP1182 Fuel Temperature Sensor Circuit Low VoltageP1183 Fuel Temperature Sensor Circuit High VoltageP1253P1259VTEC System MalfunctionP1297 Electric Load Detector (ELD) Circuit Low VoltageP1298 Electric Load Detector (ELD) Circuit High VoltageP1300 Random MisfireP1324 Knock Sensor Power Source Circuit Low VoltageP1336 Engine Speed (RPM) Fluctuation Sensor Intermittent InterruptionP1337 Engine Speed (RPM) Fluctuation Sensor No SignalP1355 Front Ignition Coil Power Circuit MalfunctionP1359 Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit MalfunctionP1361 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent InterruptionP1361 Top Dead Center (TDC) Sensor Intermittent InterruptionP1362 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No SignalP1362 Top Dead Center (TDC) Sensor No SignalP1366 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent InterruptionP1366 Top Dead Center (TDC) Sensor 2 Intermittent InterruptionP1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No SignalP1367 Top Dear Center (TDC) Sensor 2 No SignalP1381 Cylinder Position (CYP) Sensor Intermittent InterruptionP1382 Cylinder Position (CYP) Sensor No SignalP1410 Air Pump MalfunctionP1415 Air Pump Electric Current Sensor Circuit Low VoltageP1416 Air Pump Electric Current Sensor Circuit High VoltageP1420 Nox Adsorptive Catalyst System Efficiency Below ThresholdP1438 Motor Drive Module (MDM) Overheating Signal CircuitP1438 Motor Drive Module (MDM) OverheatingP1439 Motor Drive Module (MDM) Short Circuit Sensor ProblemP1439 Motor Drive Module (MDM) Short CircuitP1440 IMA System ProblemP1445 Bypass Control ProblemP1448P1449Battery Module OverheatingP1449 Battery Cell OverheatingP1449 Battery Module Individual Voltage Input DeviationP1449 Battery Module DeteriorationP1449 Battery Module DeviationP1454 Fuel Tank Pressure (FTP) Sensor Range/Performance ProblemP1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)P1459 Evaporative Emission (EVAP) Purge Flow Switch MalfunctionP1491 Exhaust Gas Recirculation (EGR) Valve Insufficient LiftP1486 Cooling System MalfunctionP1491 Exhaust Gas Recirculation (EGR) Valve Insufficient LiftP1498 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High VoltageP1505 Positive Crankcase Ventilation (PCV) Air LeakageP1508P1519Idle Air Control Valve (IACV) Circuit MalfunctionP1509 Idle Air Control Valve (IACV) Circuit FailureP1522 Brake Booster Pressure Sensor Circuit Low VoltageP1523 Brake Booster Pressure Sensor Circuit High VoltageP1524 Brake Booster Pressure Sensor Range/Performance ProblemP1541 Climate Control Unit Signal Circuit Low VoltageP1542 Climate Control Unit Signal Circuit High VoltageP1565 Motor Commutation Signal ProblemP1568 Battery Module Individual Voltage Input ProblemP1568 Battery Module Temperature Signal Circuit ProblemP1568 Battery Cell Temperature Signal Circuit ProblemP1572 Motor Drive Module (MDM) Temperature Signal Circuit Low InputP1572 Motor Drive Module (MDM) Temperature Signal Circuit High InputP1576 Motor Drive Module (MDM) Voltge Signal Circuit Low InputP1577 High Voltage Detection Signal Circuit ProblemP1580 Battery Current Circuit ProblemP1581 Motor Power Inverter (MPI) Module Current Signal Circuit Low InputP1581 Motor Power Inverter (MPI) Module Current Signal Circuit High InputP1581 Motor Power Inverter (MPI) Module Current Signal Circuit ProblemP1582 Motor Current U Phase Signal Circuit Low InputP1582 Motor Current U Phase Signal Circuit High InputP1583 Motor Current V Phase Signal Circuit Low InputP1583 Motor Current V Phase Signal Circuit High InputP1584 Motor Current W Phase Signal Circuit Low InputP1584 Motor Current W Phase Signal Circuit High InputP1585 Motor Current Signal Circuit ProblemP1586 Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit ProblemP1607 Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit MalfunctionP1630 Transmission Control ModuleP1635 Battery Condition Monitor (BCM) Module ProbleP1639 MOTB Signal Circuit MalfunctionP1640 ACTTRQ Motor Torque Signal Circuit Low InputP1641 ACTTRQ Motor Torque Signal Circuit High InputP1642 QBATT Battery Signal Circuit Low InputP1643 QBATT Battery Signal Circuit High InputP1644 MOTFSA Signal MalfunctionP1645 MOTFSB Signal MalfunctionP1646 MOTSTB Signal MalfunctionP1647 Power Command Signal Circuit Low InputP1647 Power Command Signal Circuit High InputP1647 Engine Torque Signal Circuit Low InputP1647 Engine Torque Signal Circuit High InputP1647 Mode Signal Circuit 1 Low InputP1647 Mode Signal Circuit 1 High InputP1647 Mode Signal Circuit 2 ProblemP1647 Engine Speed Signal Circuit ProblemP1648 Battery Condition Monitor (BCM) Module Communication Signal Circuit ProblemP1648 Motor Control Module (MCM) Communication Signal Circuit ProblemP1655 CVT-FI TMA/TMB Signal Line FailureP1656 Problem in PCM-toVTM-4 Control Unit Communications CircuitP1660 A/T-FI Data Line Failure/TCM - ECM HaltP1676P1678FPTDR Signal Line FailureP1679 RSCD Signal Circuit MalfunctionP1681 A/T FI Signal A Cicuit Low VoltageP1682 A/T FI Signal A Circuit High VoltageP1683 Throttle Valve Default Position Spring Performance ProblemP1684 Throttle Valve Return Spring Performance ProblemP1686 A/T FI Signal B Circuit Low VoltageP1687 A/T FI Signal B Circuit High VoltageP1705 Short in Transmission Range Switch Circuit (More than one range position is on at thesame time)P1706 Open in Transmission Range Switch CircuitP1709 Problem Transmission Gear Selection Switch CircuitP1730 Problem in Shift Control System:Shift Solenoid Valve A and D Stuck OFFShift Solenoid Valve B Stuck ONShift Valves A, B, and D StuckP1731 Problem in Shift Control System:Shift Solenoid Valve E Stuck ONShift Valve E StuckA/T Clutch Pressure Control Solenoid Valve A Stuck OFFP1732 Problem in Shift Control System:Shift Solenoid Valve B and C Stuck ONShift Valves B and C StuckP1733 Problem in Shift Control System:Shift Solenoid Valve D Stuck ONShift Valve D StuckA/T Clutch Pressure Control Solenoid Valve C Stuck OFFP1734 Problem in Shift Control System:Shift Solenoid Valves B and C Stuck ONShift Valves B and C StuckP1738 Problem in 2nd Clutch Pressure Switch CircuitP1739 Problem in 3rd Clutch Pressure Switch CircuitP1740 Problem in 4th Clutch Pressure Switch CircuitP1750 Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control SolenoidValve Assemblies A and B, or Problem in the Hydraulic Control SystemP1751 Mechanical Problem in Hydraulic Control System of Shift Solenoid Valve B and A/T ClutchPressure Control Solenoid Valves A and B, or Problem in the Hydraulic Control SystemP1753 Problem in Torque Converter Clutch Solenoid Valve CircuitP1751P1768Problem in Torque Converter Clutch Solenoid Valve B CircuitP1773 Problem in A/T Clutch Pressure Control Solenoid Valve B CircuitP1790 Throttle Position (TP) Sensor Circuit MalfunctionP1791 Vehicle Speed Sensor (VSS) Range/Performance ProblemP1792 Problem in Engine Coolant Temperature (ECT) Sensor CircuitP1793 Manifold Absolute Pressure Sensor CircuitP1870 Problem in CVT Speed Change Control Valve Assembly CircuitP1873 Problem in CVT Pulley Pressure Control Valve Assembly CircuitP1879 Problem in CVT Start Clutch Pressure Control Valve Assembly CircuitP1882 Problem in Inhibitor Solenoid CircuitP1884 Secondary Gear Speed Sensor 2 Circuit MalfunctionP1885 CVT Drive Pulley Speed Sensor CircuitP1886 CVT Driven Pulley Speed Sensor CircuitP1888 CVT Speed SensorP1889 Problem in CVT Speed Sensor 2 CircuitP1890 Shift Control SystemP1891 Problem in Start Clutch SystemP1894 CVT Speed Change Control Valve CircuitP1895 CVT Pulley Pressure Control Valve CircuitP2101 Throttle Actuator System MalfunctionP2108 Throttle Actuator Control Module ProblemP2118 Throttle Actuator Current Range/Performance ProblemP2122 Accelerator Pedal Position (APP) Sensor 1 (Throttle Position Sensor D) Circuit Low VoltageP2123 Accelerator Pedal Position (APP) Sensor 1 (Throttle Position Sensor D) Circuit High VoltageP2127 Accelerator Pedal Position (APP) Sensor 2 (Throttle Position Sensor E) Circuit Low VoltageP2128 Accelerator Pedal Position (APP) Sensor 2 (Throttle Position Sensor E) Circuit High VoltageP2135 Throttle Position (TP) Sensor 1/2 Incorrect Voltage CorrelationP2138 Accelerator Pedal Position (APP) Sensor 1/2 (Throttle Position Sensor D/E) Incorrect VoltageCorrelationP2176 Throttle Actuator Control System Idle Position Not LearnedP2195 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Signal Stuck LeanP2197 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Signal Stuck LeanP2227 Barometric Pressure (BARO) Sensor Circuit Range/Performance ProblemP2228 Barometric Pressure (BARO) Sensor Circuit Low VoltageP2229 Barometric Pressure (BARO) Sensor Circuit High VoltageP2237 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) IP Line High VoltageP2238 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Line Low VoltageP2238 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) IP Line Low VoltageP2240 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) IP Line High VoltageP2241 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) IP Line Low VoltageP2243 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) VCENT Line High VoltageP2245 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) VCENT Line Low VoltageP2247 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VCENT Line High VoltageP2249 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VCENT Line Low VoltageP2251 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) VS Line High VoltageP2252 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Line Low VoltageP2254 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VS Line High VoltageP2255 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VS Line Low VoltageP2279 Intake Air System LeakP2413 Exhaust Gas Recirculation (EGR) System Range/Performance ProblemP2422 Evaporative Emission (EVAP) System Vent Shut Valve Close MalfunctionP2552 Throttle Actuator Control Module Relay MalfunctionP2627 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) LABEL Circuit Low VoltageP2628 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) LABEL Circuit High VoltageP2630 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) LABEL Circuit Low VoltageP2631 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) LABEL Circuit High VoltageP2646 VTEC Oil Pressure Switch Circuit Low VoltageP2647 VTEC Oil Pressure Switch Circuit High VoltageP2648 VTEC Solenoid Valve Circuit Low VoltageP2649 VTEC Solenoid Valve Circuit High VoltageP2769 Short in Torque Converter Clutch Solenoid Valve CircuitP2770 Open in Torque Converter Clutch Solenoid Valve CircuitP2A00 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance ProblemP2A03 Front A/F Sensor Circuit (Bank 2, Sensor 1) Circuit Range/Performance ProblemU0073 FCAN Malfunction (Bus-off)U0107 Lost Communication With Throttle Actuator Control ModuleU0121 FCAN Malfunction (TCS-PCM)U0155 FCAN Malfunction (Gauge Control Module-ECM/PCM)
